PROBLEM
ArcGIS AutoSetup causes the computer to continue to log into administrator account
After completing the AutoSetup of ArcGIS the computer continues to automatically login under the administrative account that was used to install the software.
Cause
The AutoLogin procedure that was activated during the installation of ArcGIS was not disabled when the install completed.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Use either of the procedures below while still logged in to the machine as an administrator to resolve the problem.
  • Go to Start > Settings > Control Panel > Users and Passwords, and click the Users tab. Check the box labeled Users must enter a user name and password to use this computer.
  • Use Microsoft's TweakUI for your version of the Windows operating system. Open TweakUI, and click the Logon tab. Uncheck the box labeled Log on automatically at System Startup. Visit the Microsoft Downloads page to download TweakUI.
Article ID:000006174
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
