English
Problem: ArcGIS Desktop Administrator is not populated
After installing ArcGIS Desktop, the Desktop Administrator does not contain any folders nor have any options.
Cause
A string value necessary to populate the Desktop Administrator was not added during the installation.
Do not use this process to enable ArcView or ArcEditor Single-Use options within the desktop administrator. To obtain access to single-use options on an existing concurrent use installation, install the Single-Use product by running setup.exe over the existing Concurrent install.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
  1. Navigate to Start > Run, type 'regedit' and click OK.
  2. Navigate to HKEY_LOCAL_MACHINE > SOFTWARE > ESRI > License.
  3. Click Edit and select New > String Value.
  4. Input the new string value the proper name and data from the list below:
ArcGIS 8.3 and 9.x
  • For ArcGIS Concurrent:
Value Name: ArcGIS_Installed
Value Data: TRUE
  • For ArcView Single Use:
Value Name: SingleUse_Installed
Value Data: Viewer
  • For ArcEditor Single Use:
Value Data: Editor
ArcGIS 8.1, 8.1.2, and 8.2
Value Data: TRUE
Value Name: ArcView_Installed
Value Data: TRUE
  1. Close the Registry Editor and re-open the Desktop Administrator; it should be populated.
    This procedure can also be applied if a concurrent use product is installed but the install needs to be changed to a single use product.
Related Information
