English
FAQ: Why is the result of translating a shapefile boolean field into ArcSDE using ArcCatalog different than the shp2sde Admin command?
Question
Answer
ArcView 3.x uses the dBASE format as the underlying database file format. The dBASE format supports a boolean field type in the format below.
Type: Logical
Data Input: ? Y y N n T t F f; ? when not initialized.
Using 'shp2sde' to convert a shapefile into ArcSDE converts the data to a string type containing the characters T, F, or ?.
ArcGIS converts the boolean field type into a Short Int field with the values of 0 or 1.
The ArcSDE administration commands pre-date the existence of ArcGIS. This inconsistency has been recorded as a known issue.
