HOW TO
Note: The information in this article applies to retired product MapObjects.
When using MapObjects-Java Standard Edition (MOJ), graphical features can be created and displayed dynamically in a Map component, such as an acetate layer. To manage the display of a dynamic layer, a developer may want to create a legend to represent the layer in a TOC. Techniques for creating a dynamic layer's legend vary in difficulty and functionality, depending on the method used to create the layer. Three primary techniques are available:
Use a FeatureLayer and let MapObjects-Java manage the legend
This technique is the easiest method for creating a dynamic layer's legend.
When creating a dynamic layer as a FeatureLayer, (for example: BaseFeatureLayer), and adding it to a Map component, a new legend will automatically be added the Map's TOC. A dynamic FeatureLayer will have the same properties as a FeatureLayer using data located on disk, such as shapefile or ArcSDE layer. Legends can also be managed in the same fashion.
Add a GraphicsLayer using a LayerEvent
When creating a dynamic layer as a GraphicsLayer, it is usually associated with an AcetateLayer object before being added to a Map. By default, no legend is created for a GraphicsLayer. To add a legend for a GraphicsLayer, a new LayerEvent can be created and processed by a Map component. A LayerEvent informs the Map component's LayerListener that a layer was added, moved, or deleted from a Map. A legend for a GraphicsLayer can be added to a TOC component using the following code:
Code: MyGraphicsLayer gLayer = new MyGraphicsLayer(); gLayer.setName("My Graphics Layer"); AcetateLayer acetateLayer = new AcetateLayer(gLayer); aMap.add(acetateLayer); LayerEvent event = new LayerEvent(acetateLayer.getLayer(), LayerEvent.ADD); aMap.getLayerset().processLayerEvent(event);
The following image provides an example of a MapObjects-Java application interface after a GraphicsLayer has been added using a LayerEvent:
The legend will not contain a symbol swatch and a Map must have a registered TOC before the LayerEvent can be processed. In addition, a TocListener must be added to the TOC to listen for events on the dynamic layer legend. For example: set layer visibility depending on the state of the check box. This technique can be used if the legend does not need a symbol swatch or the dynamic layer is a GraphicsLayer and the developer does not want to create a TOC from scratch (see next method).
Reconstruct a TOC
If using a dynamic layer created from an AcetateLayer, or the legend for a GraphicsLayer needs to display a symbol swatch, the TOC component must be reconstructed to add a legend entry. The TOC is essentially a JScrollPane containing a primary JPanel consisting of one or more secondary JPanels (Legends). The TOC and its components, such as Legends and Listeners, can be created from scratch or the existing TOC component can be included within the new primary JPanel. To include the existing TOC components, do the following. Sample code is included:
Component component = aToc.getViewport().getView();
JPanel jpp = new JPanel(); jpp.setLayout(new BorderLayout()); jpp.add(component,BorderLayout.NORTH);
Sample code:
import java.awt.*; import java.awt.event.*; import javax.swing.*; public class Dynamic_Layer extends JPanel { //CustomMouseAdapter myMouseAdapter = new CustomMouseAdapter(); com.esri.mo.ui.bean.AcetateLayer m_acetate; com.esri.mo.ui.bean.Map m_map; public Dynamic_Layer(com.esri.mo.ui.bean.AcetateLayer layer, com.esri.mo.ui.bean.Map map) { m_acetate = layer; m_map = map; // Set the layout manager for the JPanel. FlowLayout fl = new FlowLayout(); this.setLayout(fl); fl.setAlignment(FlowLayout.LEFT); fl.setHgap(3); fl.setVgap(1); //Add a check box with an ActionListener to set the visibility of the AcetateLayer final JCheckBox jcb = new JCheckBox(); jcb.setSelected(true); jcb.addActionListener(new ActionListener(){ public void actionPerformed(ActionEvent ae){ if (jcb.isSelected()) { m_map.add(m_acetate); m_map.redraw(); } else { m_map.remove((Component) m_acetate); // After removing the AcetateLayer, the Map needs to be repainted m_map.repaint(); m_map.redraw(); } } }); // Construct the legend label JTextField jtf = new JTextField("MyLayer"); jtf.setEditable(false); // Add the components, set the color and size of the legend this.add(jcb); this.add(jtf); //setBackground(Color.lightGray); setPreferredSize(new Dimension(140, 50)); /* Add a MouseListener to listen for mouse interaction with the legend JPanel. * For example, selecting a legend to make it active. */ // addMouseListener(myMouseAdapter); } public void paintComponent(Graphics g){ super.paintComponent(g); Graphics2D g2d = (Graphics2D) g; // Add the symbol swatch to the legend component java.awt.geom.Area e = new java.awt.geom.Area(new java.awt.geom.Rectangle2D.Double(17,25,15,15)); g2d.setColor(new Color(0,20,250)); g2d.fill(e); g2d.setColor(new Color(0, 0, 0)); g2d.draw(e); } }
Dynamic_Layer dyn_layer = new Dynamic_Layer(myAcetateLayer, map1); jpp.add(dyn_layer, BorderLayout.CENTER); aToc.setViewportView(jpp);
This technique can be used if an AcetateLayer needs a legend entry or the content of a TOC needs to be completely customized.
Get help from ArcGIS experts
Download the Esri Support App
