ERROR
After using the Get Data For ArcPad wizard to export layers that are projected on-the-fly and opening the exported .apm file in ArcPad the following error message is displayed:
"The map projection for layer '<layer name>' doesn't match the current map projection."
ArcPad does not support projection on-the-fly. The exported .apm file contains the projection of the data frame in ArcMap, while the exported layers contain the projections of their source data.
Get help from ArcGIS experts
Download the Esri Support App
