English
Error: COM object with CLSID {} is either not valid or not registered
Error Message
When writing MapObjects code with C#, for example:
Code:
MapObjects2.GeoEvent eventPt = new GeoEventClass();
the following error message may occur:
"COM object with CLSID {} is either not valid or not registered".
Cause
This is not a class that can be created.
Solution or Workaround
Do not use the new keyword to create the class.
Code:
MapObjects2.GeoEvent eventPt;
