English
Problem: Cluster tolerances in the tutorial exercises do not match the text
In the Geodatabase Workbook, Chapter 3, Exercises 5 and 7, and Chapter 4, Exercises 8 and 9, the default cluster tolerances calculated by the software are different from the cluster tolerances illustrated and discussed in the text.
Cause
The method for calculating the cluster tolerance for a topology changed after the book was completed.
Solution or Workaround
Accept the default cluster tolerances calculated by the software.
