ERROR
CONNECT on Tru64 to Oracle 8i fails with '/arcexe83/bin/dbi_oracle: /sbin/loader: Fatal Error: cannot map'
Error Message
Trying to CONNECT to an Oracle 8i database on Tru64 fails with the error:
Code:
Arc: connect oracle system/manager
123:/archome/arcexe83/bin/dbi_oracle: /sbin/loader:
Fatal Error: cannot map libclntsh.so.8.0
Server arcgis, pid: 123 terminated normally
Cause
The ArcInfo executable DBI_ORACLE fails to find the Oracle library libclntsh.so.8.0 located in $ORACLE_HOME/lib.
Solution or Workaround
Add $ORACLE_HOME/lib to the system variable $LD_LIBRARY_PATH.
    Article ID:000006126
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
