PROBLEM
When using the Workstation DISSOLVE command on a polygon coverage, polygons that border the universal polygon are being removed.
The universal or outer boundary polygon is incorrectly coded with either a nonzero or nonblank item value for the the item(s) specified in the DISSOLVE command.
Arc: tables
Tables: select soils.pat
Tables: reselect $recno = 1
1 Records Selected
Tables: move '' to vegetation
Arc: tables
1 Records Selected
Tables: calculate vegetation = 0
Get help from ArcGIS experts
Download the Esri Support App
