HOW TO
Unlike the ServletConnector, the ActiveX Connector has no way to natively load balance among Application Servers. There are several options, but the most flexible and widely adopted algorithm is a simple Round-Robin type of load balancing, which keeps a list of the Application Servers, and forwards each request to the next Application Server in the list. Add the following code to the ArcIMS ActiveX Connector application.
Code:
<%@ Language=VBScript %>
<% Option Explicit %>
Const MAP_SERVICE = "SantaClara"
Dim cn, map, url
Set cn = Server.CreateObject("aims.ArcIMSConnector")
cn.ServerName = NextAppServer()
cn.ServerPort = 5300
Set map = Server.CreateObject("aims.Map")
map.InitMap cn, MAP_SERVICE
map.Width = 500
map.Height = 300
map.Refresh
url = map.GetImageAsUrl()
<HTML>
<HEAD>
</HEAD>
<BODY>
<%Response.Write "Using: " & cn.ServerName %>
<P align=center>
<IMG SRC="<% =url %>">
</P>
</BODY>
</HTML>
Function NextAppServer()
Dim lastServerIdx
Dim nextServerIdx, nextServerName
' add Application Servers here
Dim aryAppServers(1) ' 2 app servers
aryAppServers(0) = "APPSERVER_1"
aryAppServers(1) = "APPSERVER_2"
lastServerIdx = Application("svr")
If lastServerIdx = "" Then '1st time
lastServerIdx = LBound(aryAppServers) ' use the first app server
nextServerIdx = lastServerIdx
Else
nextServerIdx = lastServerIdx + 1
If nextServerIdx > UBound(aryAppServers) Then
nextServerIdx = LBound(aryAppServers)
End If
End If
Application.Lock
Application("svr") = nextServerIdx
Application.UnLock
nextServerName = aryAppServers(nextServerIdx)
If nextServerName = "" Then nextServerName = "localhost"
NextAppServer = nextServerName
End Function
Get help from ArcGIS experts
Download the Esri Support App
