English
FAQ: Are version names case-sensitive when using ArcSDE administration commands?
Question
Answer
The version name is stored as a character string in the versions table within the database using the same case that is input within the UI or command-line interface. When the database searches for a version name, it performs a string comparison looking for an exact match. If the database is case-sensitive, using sde administration commands will require reference to the exact case of the version name to return correct results.
Oracle/DB2/PostgreSQL:
Version names are case-sensitive.
SQL Server
Version names are not case-sensitive, meaning the string 'sde.default' is equivalent to the string 'sde.DEFAULT'.
Example:
Below is an example of an ArcSDE administration command run against a database that is case-sensitive. Make note that the command using the parent version name sde.DEFAULT without using proper case does not complete successfully:
Code:
>sdeversion -o create -V editor -P sde.default -u sde -p sde -i 7171 -D sde
ArcSDE 10.0 for PostgreSQL Build 685 Fri May 14 12:05:43 2010 Version
Administration Utility
Error: Version not found (-126).
Error: Unable to get parent version information.
>sdeversion -o create -V editor -P sde.DEFAULT -u sde -p sde -i 7171 -D sde
Version Administration Utility
Successfully created new version sde.editor:
Related Information
