English
Error: Geocoding using a Microsoft Access database table as the address table returns 'Syntax error (missing operator) in query expression'
Error Message
Geocoding using a Microsoft Access database table as the address table results in the following error:
"There was an error trying to process this table.
General function failure [table name]
Syntax error (missing operator) in query expression 'field name'."
Cause
The address table contains a field or fields that either begin with a number, contains a space, or contains the '&' or '^' symbols.
Solution or Workaround
Edit the table using Microsoft Access to remove the number, space, or odd character in the field name.
Related Information
