Dropdown lists appear on top of topics instead of below.
Cause
The system uses large fonts, which causes MapStudio to display incorrectly.
Solution or Workaround
Change the screen display to small fonts. The following steps are for Windows 2000 and Windows XP. If you are using a different platform, your steps may be slightly different.
- Click the Start Menu.
- Click Settings.
- Click Control Panel.
- Click Display.
- Click the Settings tab.
- Click the Advanced button.
- Click Small Fonts from the Font Size dropdown list. Click Normal Size if using Windows XP.
- Restart the computer.
