English
Problem: Red lines appear in the map view
When zooming out to the full extent
of U.S. maps and adding weather data, red
lines appear in the map view.
Cause
The red lines show the area that MapStudio has licensed from Meteorlogix, the weather data provider.
Solution or Workaround
Set the crop box inside the licensed area to avoid having red lines appear in the map file.
