ERROR
FLEXlm error -15 on notebook computer with a port replicator
Error Message
Running a local license manager on a laptop that also has a port replicator, may result in a -15
"Cannot connect to license manager", or similar error message relating to the resolution of the hostname.
Cause
The laptop may be using its built-in network interface card (NIC) to connect to the network, and to connect to the port replicator when docked. The laptop's hostname may be associated with two different IP addresses. This can cause the license manager to crash unexpectedly or fail to connect.
Solution or Workaround
Set the license manager to 127.0.0.1 instead of the hostname of the machine. This is the loopback/localhost address; this setting guarantees that the license will always be resolved at the local machine.
  1. Start the Desktop Administrator from Start > Programs > ArcGIS > Desktop Administrator.
  2. Click License Manager, located in the left pane.
  3. Click Change, located in the right pane, and type 127.0.0.1 as the license manager.
  4. Reboot the machine to restart the license manager.
Article ID:000006042
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
