Frequently asked question
When should a semivariogram type other than spherical be used?
Answer
The semivariogram model used in Geostatistical Analyst depends on the properties of the data. The spherical semivariogram is used by default because it is the most popular in both geostatistical literature and software. No statistical advantage is gained by using this model. From mathematical point of view, the Bessel models is recommended because they provide more flexibility in degree of smoothness when modeling a physical process. However, in comparison with the other models available in Geostatistical Analyst, the estimation of the parameters required by both the J- and K- Bessel models is a time-consuming task.
Article ID:000006020
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
