English
Problem: Author and ArcExplorer-Java Edition cannot display some HKSCS characters
The ArcIMS Author and ArcExplorer-Java Edition applications cannot display some Hong Kong Special Character Set (HKSCS) characters.
Cause
This is a known limit of version 4.0.1 of ArcIMS and ArcExplorer-Java Edition.
Solution or Workaround
Turning off Java's advance cache for fonts solves the problem and enables the display of all HKSCS characters.
  • On Windows:
    1. For Author, click Start > Programs > ArcGIS > ArcIMS and right-click on Author.
    For ArcExplorer-Java Edition, click Start > Programs > ArcGIS and right-click on ArcExplorer.
    2. Click Properties and click the Shortcut tab.
    3. Insert the parameter in the java command string in the Target field.
    For example,
    Code:
    "<path to JRE>\bin\javaw.exe" -Dsun.awt.font.advancecache=off
    -Xms24m -Xmx256m com.esri.aims.author.Main
    4. Click OK to close the Properties dialog box.
  • On Linux/UNIX:
    1. For Author, navigate to <ArcIMS Installation Directory>/ArcIMS/bin and open aimsauthor in a text editor.
    For ArcExplorer, navigate to <ArcIMS Installation Directory>/aej40exe/bin and open aejava in a text editor.
    2. Scroll to the end of the file and insert the parameter in the java command string.
    For example,
    Code:
    $JAVA_HOME/bin/java $Options -Dsun.awt.font.advancecache=off
    -cp $JARHOME/jaxp.jar: <rest of command>
    3. Save and close the file.
