English
Error: Failed to load shared library: libtiff.sl
Error Message
When the ArcSDE administration command 'sderaster' is executed on HP, the following error may occur:
"Failed to load shared library: libtiff.sl"
Example:
sderaster -o insert -l qa_rastab2,image -f 13043_500.tif -u vtest -p xx -s xavier -i 8390
ArcSDE 8.3 Build 239 Fri Nov 15 15:00:37 PST 2002
Attribute Administration Utility
Successfully created table qa_rastab2.
Incomplete...
Cause
For the HP platform, the shared library must be loaded with an absolute path; it cannot be resolved through LD_LIBRARY_PATH.
Solution or Workaround
Execute the ArcSDE administration command 'sderaster' in the directory where libtiff.sl is located. Libtiff.sl is generally located in the $SDEHOME/lib folder.
