PROBLEM
After creating a string registry in HKEY_CURRENT_USER\Software\ESRI\Geodatabase and running the Repair Connectivity command, the log file is not created.
Desktop Help incorrectly names the registry setting as 'RepaireConnectivity'.
Warning:
WARNING: This article contains instructions to make specific changes to essential parts of your operating system. If these specific changes are not done correctly, it may cause serious problems to your computer operating system and files. First, ESRI recommends that you make a complete backup of your system, including the registry, before implementing any of the specific changes. It is highly recommended that you consult with your IT/MIS department, or other qualified computer systems professional before proceeding. ESRI cannot guarantee that you can solve problems that result from incorrect use of the Registry Editor utility. Use the Registry Editor utility at your own risk. Note: your operating system and any subsequent service packs may effect these instructions. These instructions are subject to change without notice.
Get help from ArcGIS experts
Download the Esri Support App
