English
Error: Creation feature not enabled-Crystal Reports 9.0
Error Message
When Crystal Reports 9.0 is installed with ArcGIS 8.1 or 8.2, the Crystal Report Wizard will not function properly. When the Crystal Report Wizard attempts to create a new report the following error message may occur:
"Creation feature not enabled"
Cause
Crystal Reports 9.0 requires an RCAPI (Report Creation) keycode to be installed for client applications to create new reports. The ArcGIS 8.3 Crystal Report Wizard installs the RCAPI keycode.
Solution or Workaround
There is no workaround for this known issue. It has been fixed, however, in ArcGIS 8.3.
If possible, upgrade to ArcGIS 8.3.
