PROBLEM
When an Mx Extension implements IPersistVariant, the IPersistVariant_Save method is invoked when the document is saved. Under some circumstances, the IPersistVariant_Save method is not called and the extension does not have the opportunity to save anything to the stream.
The problem may be that the Extension name returned in the IExtension_Name property is longer than 31 characters.
Get help from ArcGIS experts
Download the Esri Support App
