PROBLEM
Buffer not displayed when original feature not in extent
When a buffer is drawn around a point, line or polygon feature and if that feature is not in visible extent, the buffer will not be displayed.
Cause
This is a known limit.
Solution or Workaround
For the buffer to be displayed, always set the visible extent to encompass the buffered feature.
Article ID:000005946
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
