BUG
IFeatureClass:FeatureCount & ITable::RowCount return incorrect record count
IFeatureClass:FeatureCount and ITable::RowCount return incorrect record counts after deleting a record using IFeature::Delete. This behavior only occurs with shapefiles.
Cause
This problem occurs due to a known limit in the software.
Workaround
Set IFeatureCursor equal to nothing before calling the FeatureCount or RowCount methods to return the correct row counts.
  1. Start ArcMap.
  2. Create a new UIButtonControl.
    For more information on creating a UIControl, see the ArcGIS Desktop Help topic 'How to create custom commands with VBA.'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy this code into the UIButtonControl's click event.
    Dim StrPathToDataBase As String
    StrPathToDataBase = "H:\esri_data\world_data\usa"
    ''This is the name of the ShapeFile...
    Dim StrFeatureClassName As String
    StrFeatureClassName = "States"
    ''This is the connection information that is used to access the WorkSpace...
    Dim ppropset As IPropertySet2
    Set ppropset = New PropertySet
    ppropset.SetProperty "DATABASE", StrPathToDataBase
    Dim pWorkSpaceName2 As IWorkspaceName2
    Set pWorkSpaceName2 = New WorkspaceName
    pWorkSpaceName2.WorkspaceFactoryProgID = "esriCore.ShapeFileWorkspaceFactory"
    pWorkSpaceName2.ConnectionProperties = ppropset
    Dim pname As IName
    Set pname = pWorkSpaceName2
    Dim pFeatureWorkspace As IFeatureWorkspace
    Set pFeatureWorkspace = pname.Open
    Dim pfeatureclass As IFeatureClass
    Set pfeatureclass = pFeatureWorkspace.OpenFeatureClass(StrFeatureClassName)
    Debug.Print pfeatureclass.FeatureCount(Nothing) & " FeatureCount - AD - ..."
    Dim pfeatcursor As IFeatureCursor
    Set pfeatcursor = pfeatureclass.Search(Nothing, True)
    Dim pfeat As IFeature
    Set pfeat = pfeatcursor.NextFeature
    If pfeat Is Nothing Then
    MsgBox "Nothing"
    End If
    Debug.Print pfeat.Value(0)
    pfeat.Delete
    Dim ptable As ITable
    Set ptable = pfeatureclass
    Debug.Print ptable.RowCount(Nothing) & " From Table..."
    ''If this isn't set to NOTHING the count is off...
    Set pfeatcursor = Nothing
    ''These are now correct if you set pfeatcursor = NOTHING....
    This code will delete a record in the test feature class
  5. Change the StrPathToDataBase variable to point to a directory that contains a shapefile and set the StrFeatureClassName to the name of a shapefile in that directory.
Article ID:000005930
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
