PROBLEM
Halos for markers disappear when using the Advanced Drawing Options
The halos for markers disappear when using the Advanced Drawing Options.
Cause
This is a known problem.
Solution or Workaround
The default Join setting for points in the Advanced Drawing Options is Yes. The work around is to change this setting to No for the desired point layer, and the halos will be drawn.
Article ID:000005910
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
