English
How To: Access a FeatureClass in a Personal GeoDatabase with IWorkspaceName
Summary
Below is a sample of how to access a FeatureClass in a Personal geodatabase with the Name objects (IFeatureClassName).
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
    For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy the following code into the UIButtonControl's click event.
    Code:
    Public Sub OpenPersonalPGDBaseNameObjects()
    ''This is how to use the IWorkspaceName interface to get access to a FeatureClass in a
    ''PersonalGeodataBase
    ''Users should change the following 2 variables**************
        ''This is directory where the FeatureClass lives...
        Dim StrPathToDataBase As String
        StrPathToDataBase = "H:\2002_VB6_ArcObjects\data\Sample.mdb"
        ''This is the name of the ShapeFile...
        Dim StrFeatureClassName As String
        StrFeatureClassName = "testData"
        ''This is the connection information that is used to access SDE...
        Dim ppropset As IPropertySet2
        Set ppropset = New PropertySet
       ppropset.SetProperty "DATABASE", StrPathToDataBase
        Dim pWorkSpaceName2 As IWorkspaceName2
        Set pWorkSpaceName2 = New WorkspaceName
        ''Notice this is a String. The ArcObjects help should have a listing of the
        ''other types (featureclass, tables, etc etc)
        pWorkSpaceName2.WorkspaceFactoryProgID = "esriCore.AccessWorkspaceFactory"
        pWorkSpaceName2.ConnectionProperties = ppropset
        Dim pname As IName
        Set pname = pWorkSpaceName2
        Dim pFeatureWorkspace As IFeatureWorkspace
        Set pFeatureWorkspace = pname.Open
        Dim pfeatureclass As IFeatureClass
        '''Look at the IFeatureWorkSpace as you can open Tables, DataSets, etc etc...
        '''Below we use IFeatureWorkSpace::OpenFeatureClass to get a FeatureClass...
        Set pfeatureclass = pFeatureWorkspace.OpenFeatureClass(StrFeatureClassName)
        ''Proving you have a featureclass...
        MsgBox pfeatureclass.FeatureCount(Nothing)
    End Sub
