HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Below is a code sample showing how to access a FeatureClass residing in SDE using IFeatureClassName.
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
''This is how to Use the IWorkspaceName interface to get access to an SDE ''WorkSpace and a dataset residing within it... ''Users should change the following variable************** ''This is the name of the FeatureClass... Dim StrFeatureClassName As String StrFeatureClassName = "sde.SDE.roads" ''**************************************************** ''This is the connection information that is used to access SDE... Dim ppropset As IPropertySet2 Set ppropset = New PropertySet ppropset.SetProperty "SERVER", "Brazil" ppropset.SetProperty "INSTANCE", "5151" ppropset.SetProperty "USER", "sde" ppropset.SetProperty "PASSWORD", "sde" ppropset.SetProperty "VERSION", "SDE.DEFAULT" Dim pWorkSpaceName2 As IWorkspaceName2 Set pWorkSpaceName2 = New WorkspaceName pWorkSpaceName2.ConnectionProperties = ppropset ''Notice this is a String. The ArcObjects help should have a listing of the ''other types (featureclass, tables, etc etc) pWorkSpaceName2.WorkspaceFactoryProgID = "esriCore.SdeWorkspaceFactory" Dim pname As IName Set pname = pWorkSpaceName2 Dim pFeatureWorkspace As IFeatureWorkspace Set pFeatureWorkspace = pname.Open Dim pfeatureclass As IFeatureClass '''Look at the IFeatureWorkSpace as you can open Tables, DataSets, etc etc... '''Below we use IFeatureWorkSpace::OpenFeatureClass to get a FeatureClass... Set pfeatureclass = pFeatureWorkspace.OpenFeatureClass(StrFeatureClassName) ''Proving you have a featureclass... MsgBox pfeatureclass.FeatureCount(Nothing)
Get help from ArcGIS experts
Download the Esri Support App
