PROBLEM
Nothing happens when I try to insert legend, north arrow, scale bar, or scale text
When I try to insert a legend, north arrow, scale bar, or scale text using the Insert menu nothing happens.
Cause
The active data frame is grouped with other elements.
Solution or Workaround
Select the group element that contains the active data frame in the layout, right-click on it and click ungroup.
Now you will be able to insert map surrounds.
    Article ID:000005885
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
