ERROR
Component crviewer9.dll or one of its dependencies not registered correctly
Error Message
While using Crystal Reports 9.0 and ArcMap, you may receive an error:
"Component crviewer9.dll or one of its dependencies not registered correctly".
Cause
This is a known issue.
Solution or Workaround
Uninstall and reinstall Crystal Reports 9.0.
  1. Uninstall Crystal Reports 9.0.
    A. Clicking Start > Settings > Control Panel.
    B. Double-click Add/Remove Programs.
    C. Click Crystal Reports for ESRI > Remove > Remove All > Next > Finish.
  2. Reinstall Crystal Reports 9.0:
    Insert the Crystal Reports 9.0 CD in the CD-ROM drive and follow the onscreen installation instructions.
Article ID:000005872
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
