English
Bug: Cannot create a Web site using an ArcMap Service
When you try to create an HTML or Java Web site using an ArcMap Service, ArcIMS Designer hangs and does not allow you to create the site.
Cause
You can create an ArcMap service using an ArcMap MXD document that contains an empty group layer, but you will not be able to create a site that utilizes this service.
Workaround
  1. Open the ArcMap docuement and remove the empty group layer from the map.
  2. Resave the ArcMap Document.
  3. Refresh the ArcMap Service.
  4. Create the Web site.
Related Information
