Answer
- ArcMap Server (ArcIMS 4.0) supports the following:
8.2 ArcMap documents (MXD & PMF)
- ArcMap Server (ArcIMS 4.0) does not support the following:
8.3 ArcMap documents (MXD & PMF)
9.0 ArcMap documents (MXD & PMF)
9.1 ArcMap documents (MXD & PMF)
- ArcMap Server (ArcIMS 4.0.1) supports the following:
8.3 ArcMap documents (MXD & PMF) including ArcMap documents that have layers based on a table query.
- ArcMap Server (ArcIMS 4.0.1) does not support the following:
8.3 ArcMap functionality such as, topology, Survey Analyst datasets and displaying dynamic segmentation symbology based on dynamic fields (such as, LOC_ANGLE and LOC_ERROR).
- ArcMap Server (ArcIMS 9.0) supports the following:
- ArcMap Server (ArcIMS 9.0) does not support the following:
9.2 ArcMap documents (MXD & PMF)
- ArcMap Server (ArcIMS 9.1) supports the following:
- ArcMap Server (ArcIMS 9.1) does not support the following:
- ArcMap Server (ArcIMS 9.2) supports the following:
- ArcMap Server (ArcIMS 9.3) supports the following:
9.3 ArcMap documents (MXD & PMF)
