ERROR
Validate Topology failed. The number of errors generated during the topology analysis exceeds the specified threshold
Error Message
Validate of a topology fails with the error message:
"Validate Topology failed.
The number of errors generated during the topology analysis exceeds the specified threshold.
A failure was detected inside the topology engine overaly processor. [error id: -2147214997]"
Cause
The number of errors generated during Validate has exceeded the maximum number of allowable errors for the topology. This value can only be set programmatically and is specified by the maxGeneratedErrorCount parameter on the ITopologyContainer::CreateTopology method.
Topologies created with ArcCatalog have a maxGeneratedErrorCount of -1 and no limit to the number of errors generated during validate.
Solution or Workaround
There are 2 possible solutions:
  • Drop and rebuild the Topology with a larger maxGeneratedErrorCount value or a value of -1.
  • Validate the topology within ArcMap incrementally, fixing the errors as they are discovered, so the maxGeneratedErrorCount threshold is never reached.
Article ID:000005822
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
