PROBLEM
When getting feature information using the Web Map Services (WMS) Connector in ArcIMS 3.1, the following error message may occur:
"Error: 500
Internal Servlet Error:
java.util.NoSuchElementException
at java.util.StringTokenizer.nextToken(Unknown Source)
at java.util.StringTokenizer.nextElement(Unknown Source)"
When using the WMS Connector to perform a FeatureInfo request, the above error will occur if the returned data contains spaces. For instance, if the data returned included 'Los Angeles' then you would receive this error. This is only a problem at ArcIMS 3.1.
Get help from ArcGIS experts
Download the Esri Support App
