Summary
Information provided is for uninstalling ServletExec 3.1 servlet engine configured with IIS on Windows NT, 2000 and XP.
Procedure
- Stop the IIS Admin Service from the Windows Services panel.
- Uninstall ServletExec 3.1 ISAPI using the Add/Remove Programs Dialog.
A. Navigate to Control Panel > Add/Remove Programs.
B. Select ServletExec 3.1 ISAPI from the list of available programs and click Change/Remove.
C. At the Warning telling you to stop IIS, click OK.
D. At the window asking you if you wish to have the installer delete the ServletExec Directory, click Yes.
E. At the window informing you that ServletExec has been removed, click OK.
- Check to ensure that ServletExec directories have been removed.
A. Open Windows Explorer.
B. Navigate to the Servlet Exec installation directory. The default for ServletExec ISAPI is C:\Program Files\New Atlanta\ServletExec ISAPI and for ServletExec AS it is C:\Program Files\New Atlanta\ServletExec AS respectively.
C. Remove the New Atlanta folder, if it still exists.
