Frequently asked question
Where do I get the error message corresponding to a giomgr exit code?
Answer
The exit codes are documented in the topic 'Return Codes' under the C API Function reference section in ArcSDE Developer Help. The ArcSDE Developer help is available on all the ArcSDE install CDs as well as at the ESRI Online Support Center. The exit codes are also defined in the sdeerno.h file that is installed, in the $SDEHOME\include directory, with the ArcSDE C API Client.
EDN also has a page with the return codes here: ArcSDE 9.2 Return Codes.
Article ID:000005786
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
