English
FAQ: What level of schema validation is performed when making reuse schema checkout?
Question
Answer
A basic check for the presence of duplicate datasets is performed. There is no validation of topology cluster tolerances, network configurations, subtypes, domains, etc. The checkout process assumes that the schema of the template to be reused matches the schema of the data to be checked out from the master geodatabase.
