English
FAQ: Why is a pull check-in wizard sometimes received instead of a push checkout from the ArcSDE checkout geodatabase?
Question
Answer
The ArcSDE checkout geodatabase that is being checked in is currently hosting checkouts to other geodatabases.
To complete the check-in, either do a pull check-in from the master geodatabase or check in all the other checkouts to your geodatabase. When all the other checkouts have been checked in, you will be able to complete a push check-in from your ArcSDE checkout geodatabase to the master geodatabase.
