English
FAQ: Why aren't the changes made in the ArcSDE checkout geodatabase checked in?
Question
Answer
Only the changes made to the checkout version, created in the ArcSDE geodatabase when the checkout was made, will be checked in. Any edits made to any other version in the checkout ArcSDE geodatabase will not be checked in. Make sure that you are editing the correct version.
