English
How To: Configuring Tomcat 4.0.5 (or 4.1.12) for Apache 2.0.42 for Metadata Explorer
Summary
If you wish to use Metadata Explorer, you must configure your Web server:
Procedure
  1. Edit the $CATALINA_HOME/conf/mod_jk.conf file. Open the mod_jk.conf file in a text editor and add the following to your VirtualHost session. For example:
    <VirtualHost Your_server_name>
    ServerName Your_server_name
    Code:
    JkMount /metadataexplorer ajp13
    JkMount /metadataexplorer/* ajp13
    </VirtualHost>
  2. Copy the \metadataexplorer directory from the <ArcIMS Installation Directory>/ArcIMS/Metadata directory to the $CATALINA_HOME/webapps directory. For example:
    Code:
    cp -r <ArcIMS Installation Directory>/ArcIMS/Metadata/metadataexplorer $CATALINA_HOME/webapps
  3. Stop the Tomcat and Apache services. To stop Tomcat:
    Code:
    $CATALINA_HOME/bin/shutdown.sh
    To stop Apache:
    Code:
    <Apache Installation Directory>/bin/apachectl stop
  4. Start the Apache and Tomcat services. To start Apache:
    Code:
    <Apache Installation Directory>/bin/apachectl start
    To start Tomcat:
    Code:
    $CATALINA_HOME/bin/startup.sh
    See the Creating and Using Metadata Services on the ArcIMS install CD for information on Metadata Explorer.
Related Information
