PROBLEM
ArcReader does not support hyperlink Macros
ArcReader does not support hyperlink Marcos created in ArcMap and Visual Basic for Applications (VBA).
Cause
The ArcReader Help system in topic "Exploring data on a map" incorrectly states that Marcos are a supported type of hyperlink. ArcReader does not support VBA macros. VBA is not included in the ArcReader application like ArcMap and ArcCatalog.
Solution or Workaround
There is no solution for supporting hyperlinks to VBA macros in ArcReader. ArcReader only supports hyperlinks to documents or URLs.
Article ID:000005737
Software:
  • ArcReader 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
