Summary
Instructions provided are for uninstalling ServletExec 4.1.1_AS that has been installed and configured to work with the Apache Web Server on Windows NT, 2000 and XP.
Procedure
- Stop the Apache Service.
A. Navigate to the services panel.
B. Scroll through the list until you find the Apache Service, right click on the service and select Stop.
- Uninstall ServletExec 4.1.1 AS using the Add/Remove Programs.
A. Navigate to Control Panel > Add/Remove Programs.
B. Select ServletExec 4.1.1 AS from the list of available programs, and click Change/Remove.
C. At the ServletExec 4.1.1 Application Server Setup window, click Next.
D. At the Setup Type window, select 'Uninstall ServletExec Completely', and click Next.
E. At the Warning box, verify that all ServletExec instances have stopped and click OK.
F. At the Question box prompting you to have the uninstaller remove the directory location, click Yes.
G. When the Information box appears, click OK to finish the uninstall.
