HOW TO
Uninstall ServletExec 4.1.1 that has been configured with IIS on Windows NT, 2000, and XP
Summary
Instructions provided are for uninstalling ServletExec 4.1.1 servlet engine configured with IIS on Windows NT, 2000 and XP.
Procedure
  1. Stop the IIS Admin Service from the Windows Services panel.
  2. Uninstall ServletExec 4.1.1 ISAPI using the Add/Remove Programs dialog box.
    A. Navigate to Control Panel > Add/Remove Programs.
    B. Select ServletExec ISAPI 4.1.1 from the list of available programs and click Change/Remove.
    C. When asked if you would like to Uninstall ServletExec ISAPI, click Yes.
    D. At the warning telling you to stop IIS, click OK .
    E. At the window asking if you wish to have the installer delete the ServletExec Directory, click Yes.
    F. At the window informing you ServletExec has been removed, click OK.
  3. Check to ensure that ServletExec directories have been removed.
Article ID:000005727
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
