English
How To: Uninstall Jakarta Tomcat 3.2.3 on Windows NT/2000/XP
Summary
Instructions provided are for uninstalling the Jakarta-Tomcat 3.2.3 servlet engine on Windows NT/2000/XP.
Procedure
· Certain Windows skills are required to perform the following procedure.
For details on these skills please see: Common Windows Tasks when installing ArcIMS
  1. Open the Services Panel.
  2. Stop any ArcIMS services such as ArcIMS Tasker, Monitor or Application Server.
  3. Stop the 'IIS Admin Service'.
  4. Find and stop the service called 'Jakarta' or 'Tomcat'.
  5. Open a command prompt window and navigate to the 'bin' directory of the jakarta-tomcat installation directory. For example, <drive>:\jakarta-tomcat-3.2.3\bin.
  6. A. If you have a file called TomcatService.exe in your Tomcat bin directory, type the following at the command prompt and press Enter:
    TomcatService -uninstall Jakarta (If you have a Jakarta Service)
    TomcatService -uninstall Tomcat (If you have a Tomcat Service)
    [O-Image] ScreenShot - Remove Jakarta Service using TomcatService -uninstall on Win
    B. If, instead, you have a file named jk_nt_service.exe, then type the following at the command prompt and press Enter:
    jk_nt_service -r Jakarta (If you have a Jakarta Service)
    jk_nt_service -r Tomcat (If you have a Tomcat Service}
    [O-Image] ScreenShot - Remove Tomcat Service using jk_nt_service on Win
  7. In Windows Explorer, browse to your jakarta-tomcat installation directory. For example, <drive>:\jakarta-tomcat-3.2.3.
  8. Delete your jakarta-tomcat-3.2.3 installation directory.
  9. Open the Windows Registry Editor.
    Warning:
    This article contains instructions to make specific changes to essential parts of your operating system. If these specific changes are not done correctly, it may cause serious problems to your computer operating system and files. First, ESRI recommends that you make a complete backup of your system, including the registry, before implementing any of the specific changes.
    It is highly recommended that you consult with your IT/MIS department, or other qualified computer systems professional before proceeding. ESRI cannot guarantee that you can solve problems that result from incorrect use of the Registry Editor utility. Use the Registry Editor utility at your own risk. Note: your operating system and any subsequent service packs may effect these instructions. These instructions are subject to change without notice.
  10. With the left mouse button select the Key: HKEY_LOCAL_MACHINE\SOFTWARE\Apache Software Foundation.
  11. Right-click the selected key in Step 10 and click Delete.
  12. Close the Registry Editor.
