English
Error: Error opening feature class: Attribute conversion error[owner.TABLE][STATE_ID =n]
Error Message
When trying to open a feature class in ArcMap or ArcCatalog, the following error occurs:
"Error opening feature class
Attribute conversion error[MINN.UG_PARPTS_GEOM][STATE_ID =0]"
Cause
The table may contain one or more columns defined as user defined data types. ArcGIS does not interpret most user defined types because they cannot be mapped to ArcSDE data types. (SDO_GEOMETRY is one exception.)
Solution or Workaround
Do not use register tables or feature classes that contain user defined types with ArcSDE.
    Related Information
