English
How To: Use WHERE clauses
Summary
Instructions provided describes how to use WHERE clauses. Spatial Query and Data Manager Web services allow the filtering of results when using a WHERE clause.
Procedure
The following are examples of some of the ways to use WHERE clauses:
  • Use a basic WHERE clause.
    For example, City='Murrieta'.
    Result: locations in Murrieta.
  • Put more than one clause together.
    AND finds records that meet both criteria:
    For example, Type='Amusement Parks' AND State='CA'.
    Result: Amusement Parks in CA.
    OR finds records that meet one or both criteria:
    For example, Type='Amusement Parks' OR State='CA'.
    Result: Amusement Parks located anywhere and all places within CA.
  • Use different types of comparison operators. These can be used with letters and numbers.
    > is strictly 'greater than':
    For example, Name>'D'.
    Result: Names beginning D-Z and characters like ~ and -.
    <= is 'less than or equal to':
    For example, Zone<='60000'.
    Result: Zones 60000 and smaller.
    <> is 'not equal to':
    For example, State<>'CA'.
    Result: all states that are not CA.
  • Use extended comparisons.
    BETWEEN tests whether a value is between two other values:
    For example, City BETWEEN 'E' AND 'L'.
    Result: Cities such as Fedora that fall between E and L alphabetically.
    IN tests whether a value is in a list of possible values:
    For example, Type IN ('red', 'blue', 'green').
    Result: All Types are that either red, blue or green.
  • Use LIKE for pattern matching.
    _ tests for exactly one wildcard character:
    For example, State LIKE 'W_'.
    Result: States that begin with W, such as WA, WI, WV, and WY.
    % tests for zero to multiple wildcards:
    For example, City LIKE '%ing'.
    Result: Cities that end in 'ing' such as Redding.
  • Use NOT for negating a clause.
    For example, NOT Type='red'.
    Result: Types that are not red.
Related Information
