English
Error: Segmentation fault (core dumped)
Error Message
Using sde2cov on HP 11.0, ArcSDE 8.2 (64 bit) with Oracle 9i (64 bit), the following error message will occur:
"Segmentation fault (core dumped)"
Cause
This is a known issue.
Solution or Workaround
Use ArcCatalog to export the ArcSDE Feature Class to a coverage.
