PROBLEM
Cannot access ArcMap after minimizing a Crystal Report and restarting the Crystal Report Wizard
ArcMap cannot be accessed after a Crystal Report is viewed, the report window is minimized, and the Crystal Report Wizard is reopened.
Cause
The report being viewed is in a modeless dialog box. This allows the user to minimize the report and restart the report wizard. Once reopened, the wizard is a modal dialog box, and the user is unable to access anything outside the dialog box.
Solution or Workaround
The work-around is to terminate the ArcMap session in Task Manager.
Hold down Ctrl+Alt+Del to open the Task Manager.
On the Applications tab, click ArcMap.
Click End Task and close the Task Manager.
Re-open ArcMap
Article ID:000005684
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
