English
Problem: ArcView GIS 3.x program not available in the Add/Remove Programs Properties dialog box
The ArcView GIS 3.x program is not listed in the Add/Remove Programs Properties dialog box.
Cause
There is a problem with the uninstall registry entry.
Solution or Workaround
Log in with the same username you used when installing ArcView GIS 3.x.
The ArcView GIS 3.x program will only appear in the Add/Remove Programs Properties dialog box if you are logged in under the same username you originally used to install ArcView GIS 3.x.
