ERROR
Starting the ArcIMS Monitor 4.0 service reports the following error:
"Could not start ArcIMS Monitor 4.0 on the local computer. Error 1067: The process terminated unexpectedly."
The sde.properties file is not created with correct values of the variables. The sde.properties file is created if you choose to install the Service Administrator while you are installing ArcIMS 4.0.
sdePropertiesFilename=Sde.propertiesAfter:
#sdePropertiesFilename=Sde.properties
autoSdeResurrect=False autoSdeRestore=False instanceNames=esri_sde portNumbers=5151 sdehomes=C:/ArcGIS/ArcSDE/ora9iexe sdeSiteFilename=SdeSite.xml sdeStartTimeout=300
Get help from ArcGIS experts
Download the Esri Support App
