English
Problem: ArcSDE Java API: The SeShape.getArea() method returns an incorrect area value
When the SeShape.getArea() method is invoked on an SeShape object, the resultant area value is incorrect.
Cause
This occurs whenever the SeShape.getArea() method is called after the invocation of any SeShape method that uses the ArcSDE Java API native libraries. For example, if the SeShape.getArea() is called after the invocation of the SeShape.intersect() method, the area value returned is incorrect.
Solution or Workaround
Install ArcSDE Java API version 8.3 Beta 2 or higher.
