PROBLEM
When running the ArcView Projection Utility with an Event Theme, the following error is given.
"Error in APU.Run at 447
Stop: A(n) Nil object does not recognize request GetExtension."
The ArcView Projection Utility can only processes shapefiles. It can not process virtual FThemes such as Event Themes.
Get help from ArcGIS experts
Download the Esri Support App
